Command Value
This documentation provides recommendations for command values (action or info) based on command types. While following these recommendations is not mandatory, doing so is strongly advised for better integration with Jeedom.
Lighting
Generic Type Values / Action
Info/Light Status Brightness
0–100, 0–99, or 0–255
(based on the maximum Action/Light Slider setting)
or Binary
0 = Off
non-zero = On
Required
Info/Lighting Brightness Brightness
Always use with “Light Status” on the binary command
Action/Light Slider Dimmer
Min&Max Required
Action/Light On Button Turn on the light (Change state)
Action/Light Off Button Turn off the light (Change state)
Info/Color Light Format #RRGGBB
Action/Color Light Change Color, Format #RRGGBB
Info/Light, Temperature, Color Mired Format (<=500) ou Kelvin (>500)
Action/Light, Temperature, Color Changing the color temperature
Min&Max Required
Action/Light Toggle Invert state if binary
Action/Lighting Mode Preset/Lighting Scene (can be multiple)
Outlet
Info/Outlet
Status
0 = Off
1 = On
Action/Outlet
On Button
Turn on the outlet
Action/Outlet
Off Button
Turn Off the Outlet
Switches
Info/Switch
Status
0 = Off
1 = On
Action/Switch
On Button
Turn on the switch
Action/Switch
Off Button
Turn Off the Switch
Fan
Info/Fan
Status
0 = Off
1 = On
or dimming if speed
Action/Fan
On Button
Turn On
Action/Fan
Off Button
Turn Off
Action/Fan
Speed
Rotation
Min Max Required
Shutter
Info/Shutter Status If Binary:
0 = Closed
1 = Open
Si Numérique:
min from the Slider button (otherwise min from the State, otherwise 0) = Closed
Slider Button max (else State max, else 100) = Open
If there is no slider button: Min and Max are required in the State!
Action/Shutter Button: Raise Open the shutter
Trigger opening, or set slider value to maximum, or state, or 100
Action/Shutter Button: Lower Close the shutter
Initiate closing, or set the slider to its minimum value, or set the status to 0
Action/Shutter Stop Button Stop shutter movement
Action/Shutter Slider Button Returns the shutter’s opening percentage
If present:
optional:
Info/Shutter Status & Horizontal Angle Angle 0–90° (via slider)
Action/Shutter Slider—Horizontal Tilt Angle 0–90°
adjustable using the slider’s min-max values
Info/Shutter Status: Vertical Angle Angle 0–90° (via slider)
Action/Shutter Slider Vertical Tilt Angle 0–90°
Valves
Info/Faucet
Status
0 = Off
1 = On
Action/Faucet
On Button
Turn On
Action/Faucet
Off Button
Turn Off
Info/Irrigation
Status
0 = Off
1 = On
Action/Irrigation
On Button
Turn On
Action/Irrigation
Off Button
Turn Off
Info/Valve
General
Status
0 = Off
1 = On
Action/Valve
General
On Button
Turn On
Action/Valve
General
Off Button
Turn Off
Add a dimmer? And add digital control to the action? Is that even possible?
Locks
Info/Lock Status 0 = Unsecured (Unlocked)
1 = Secure (Locked)
Action/Lock Open Button Unlock
Action/Lock Button Lock
Motion
Info/Presence 0 = No movement
1 = Motion
Home
Info/Port
Info/Window
(same processing)
0 = Contact (Closed)
1 = No contact (Open)
Alarms
Status Info/Siren 0 = Not sounding
1 = Ring
Alarm
Status Info/Alarm 1 = Triggered
(takes precedence over “On” and modes)
Status Info/Alarm Enabled 0 = Disarmed
(takes precedence over modes)
Info/Alarm Mode Label displaying exactly the name of an Action/Alarm Mode command
Action/Alarm Armed Arms the alarm
Action/Alarm triggered Disarm the alarm
Action/Alarm Mode Alarm mode; can be multiple
Thermostats
Info/Thermostat Status (BINARY) 0 = Off
1 = On
Info/Thermostat Status (HUMAN) ‘off’ or ‘stopped’ or ‘off’
“heat” or “heating”
“cooling” or “air conditioning”
Prefer English
Info/Thermostat Mode ‘Off’ or ‘Arret’ = OFF
‘None’ or ‘Thermostat’ = Setpoint Mode
Label displaying exactly the name of an Action/Thermostat mode command
Action/Thermostat Mode Thermostat mode; may be multiple
Info/Outdoor Temperature Thermostat Degrees Celsius
Info/Thermostat Room Temperature Degrees Celsius
Info/Setpoint Thermostat Value between Min and Max of the Action/Setpoint Thermostat
Action/Setpoint Thermostat Required Min & Max
Info/Thermostat Lock 0 = Unlocked
1 = Locked
Action/Thermostat Lock Lock the thermostat
Action/Thermostat Unlock Unlock the thermostat
Gates or Garages
Info/Door-Opening Status Portal
Info/Garage door status
(same handling)
0 = Closed
252 = Locking in progress
253 = Stopped
254 = Opening in progress
255 = Open
(Based on Z-Wave equipment; could this also be binary or labeled?)
with either:
Action/Portal or garage toggle button Switch that turns on when closed and turns off when open
Opens if locked (for security)
or:
Action/Portal or garage door opener button Open
Action/Portal or garage door close button Close
Electrical
Generic Type Unit
Info/Electrical Power Watts
Info/Electricity Consumption kWh
Miscellaneous
Generic Type Values / Unit
Info/Occupancy 0 = No one
1 = Someone
Info/Air Quality (AQI) AQI
Info/Air Quality (Customizable Index) ppb or µg/m³
Info/CO Detector 0 = CO levels are normal
1 = Abnormal CO
Info/Brightness 0 → 100,000 lux
Info/Humidity %
Info/CO2 (ppm) PPM or binary?
Info/Temperature -50 → 300 °C
Info/Battery %
Info/Battery Charging 0 = NO
1 = YES
Not listed = Not rechargeable
Info/Low Battery 0 = NO
1 = YES
Info/Smoke Detection 0 = No smoke
1 = Smoke detected
Info/Flooding
Info/Water Leak
0 = No leak detected
1 = Leak detected
Info/Tampering 0 = No tampering
1 = Tamper
Info/Shock 0 = No shock
1 = Shock
Info/Pressure bar
Info/Sound (dB) dB
Device Status
Info/Status Active 0 = inactive
1 = active
Info/Online Connectivity 0 = offline
1 = online
Info/Status: Defective 0 = no
1 = yes
