Publish a plugin on the marketplace
Prerequisites
INFORMATION
If you are registered as a developer on the marketplace but do not have write access to the Developers’ Forum so that you can post a message, you need to submit a support request.
Plugin Overview
You must have posted a description of your plugin on the forum before submitting a request to upgrade to the stable version.
We recommend writing this presentation as soon as the plugin is first released in beta—or even as soon as it’s functional via a simple GitHub link. There are several advantages to presenting your plugin early:
Presentation Format
It is up to each developer to decide what information to provide; officially, only the following fields are required:
Tags
Various tags are available on the forum to help you categorize your plugin:
Once the plugin has been marked as stable, a dedicated tag must be assigned to it in the form plugin-ID_PLUGIN so you can easily find topics related to it. If this tag hasn’t been created for some reason, you can start a thread on the forum or submit a support request.
Publication
To publish a new plugin, log in to the Market with your developer account, then click the Market menu and select Add. All that’s left to do is enter the plugin’s details:
Once you’ve entered this information, you can click the VALIDATE button. If everything is configured correctly, the marketplace should perform an initial synchronization of the plugin. All that’s left to do is edit the plugin’s details to fill in the various Branches (be sure to click VALIDATE before running a TEST):
INFORMATION
By default, your plugin author name is your Market ID. To change it, go to your Market Profile and fill in the Author field in the For Developers section.
Synchronization
All plugins are automatically synced with the Market every day starting at 1 a.m. You can also manually sync a specific branch by clicking the GitHub beta or GitHub stable button on the plugin’s Market page.
It is this synchronization step (daily, automatic, or manual) that triggers a plugin update alert for users and updates the Market listing.
