There are several ways to create custom widgets for plugins:
Nothing special there—the toHtml function should return the widget as HTML. Here’s an example: there
The most important part is the first few lines:
$replace = $this->preToHtml($_version);
if (!is_array($replace)) {
return $replace;
The preToHtml function returns:
The widget template system in the code is actually exactly the same as the one on the Tools -> Widgets page in Jeedom.
Here is an example:
public static function templateWidget(){
$return = array('info' => array('string' => array()));
$return['info']['string']['state'] = array(
'template' => 'tmplmultistate',
'test' => array(
array('operation' => '#value# == 2','state_light' => '<i class="icon maison-vacuum6"></i>','state_dark' => '<i class="icon maison-vacuum6"></i>'),
array('operation' => '#value# == 3','state_light' => '<i class="fa fa-pause"></i>','state_dark' => '<i class="fa fa-pause"></i>'),
array('operation' => '#value# > 3 || #value# < 2','state_light' => '<i class="fa fa-home"></i>','state_dark' => '<i class="fa fa-home"></i>')
return $return;
Here, we’re going to create a new widget based on the “tmplmultistate” template (you have the list of templates here these are the ones with “tmpl” in their names), for a command of type “info” and subtype “string.”
Each template is designed for a specific type and subtype, so be sure to verify that the template you want to use is available for that type and subtype.
Next, since this is a template with multiple states, you need to define the icons based on the state. This is done in the test section of the table.
Example: For the first test, if the command value is 2, then the tag #_state_# (in the template’s HTML code) must be replaced with
Another example based on a different template could be:
$return['info']['binary']['toto'] = array(
'template' => 'tmplicon',
'replace' => array(
'#_icon_on_#' => '<i class=\'icon_green icon jeedom-porte-ferme\'></i>',
'#_icon_off_#' => '<i class=\'icon_red icon jeedom-porte-ouverte\'></i>'
return $return;
Here, I’m creating a “toto” widget based on the “tmplicon” template, with the type set to “info” and the subtype set to “binary.” When its value is 1, the icon will be and when it’s 0, it will be
TIPS
Here’s a quick tip: Instead of an icon, you can use an image tag (be careful with the path).
Next, to use your widget:
$cmd->setTemplate('dashboard','neato::state');
$cmd->setTemplate('mobile','neato::state');
It’s just like a normal widget, except that the widget name follows the format id_plugin::widget_name. For the second example, it would be id_plugin::toto
