Home → Dashboard
The dashboard is one of the main pages of Jeedom, it displays a report of all your home automation. This report (unlike views and designs) is self-generated by Jeedom, and includes all of the visible objects and their equipment.
The display order of objects on the Dashboard is visible in Analysis → Home automation summary. You can modify this order on this page by dragging and dropping.
For equipment to appear on the Dashboard, it must :
When the equipment first appears on the Dashboard, Jeedom tries to correctly size its tile to display all of the commands and their widgets. In order to keep a balanced dashboard, you can switch to Edit mode with the pencil at the top right of the search bar, in order to resize and / or reorder the equipment tiles.
By moving the mouse over a command, a colored marker appears at the bottom left of the tile:
In addition, you can click on the title of the tile (the name of the equipment) to directly open the configuration page of this equipment.
It is possible to go directly to a single object in your home automation, via the menu Home → Dashboard → Object name. This allows you to have only the equipment that interests you, and to load the page faster.
On the far right, a button allows you to switch to edit mode, to modify the order of the tiles (click - drop on the widget), or resize them. You can also rearrange the order of commands in a tile.
By clicking on an object summary, you filter to display only the equipment related to this object and which relate to this object summary.
In edit mode (the pencil at the top right), you can change the size of the tiles and their arrangement on the Dashboard.
the equipment refresh icons are replaced by an icon allowing access to their configuration. This icon opens an editing window with the display parameters of the equipment and its controls.
On each object, to the right of its name and summary, two icons allow you to align the height of all the tiles of the object on the highest or lowest.
- Click on the clock (menu bar) : Open the Timeline.
- Click on the name of the Jeedom (menu bar) : Opens Settings → System → Configuration.
- Click on ? (Toolbar) : Opens help on the current page.
- Escape on a research field : Clear the field and cancel this search.
