Tools → Objects
The Objects allow you to define the tree structure of your home automation.
All the equipment you create must belong to an object and are therefore more easily identifiable. We then say that the object is the parent equipment.
To give free choice to personalization, you can name these objects as you wish. Usually, we will define the different parts of his house, like the name of the rooms (this is also the recommended configuration).
You have two options :
Once you have created an object, it will appear in this part.
You can open an object by doing :
- Click on one of them.
You have a search engine to filter the display of objects. The Escape key cancels the search. To the right of the search field, three buttons found in several places in Jeedom:
Once on the configuration of an object, you have a contextual menu with the Right Click on the tabs of the object. You can also use a Ctrl Click or Center Click to directly open another object in a new browser tab.
By clicking on an object, you access its configuration page. Whatever changes you make, don't forget to save your changes.
Here are the different characteristics to configure an object :
You can change the display order of objects in the Dashboard. In the overview (or by the Home Automation Summary), select your object with the mouse with a drag and drop to give it a new place.
You can see a graph representing all the elements of Jeedom attached to this object by clicking on the button Connections, top right.
When a device is created and no parent has been defined, it will have as parent : No.
Summaries are global information, assigned to an object, which is displayed in particular on the Dashboard (next to the name of the object), and on the summary (on the object’s thumbnail).
The columns represent the summaries assigned to the current object. Three lines are proposed to you :
Each tab represents a type of summary defined in the configuration of Jeedom. Click on Add a command so that it is taken into account in the summary. You have the choice to select the command of any Jeedom equipment, even if it does not have this object as parent.
If you want to add a type of summary or to configure the calculation method of the result, the unit, the icon and the name of a summary, you must go to the general configuration of Jeedom : Settings → System → Configuration : Summaries tab.
This page displays all the equipment having the object as parent. On each device, by clicking on it, the list of device info commands is presented, with on the right the means of assigning this command to one or more summaries of the object.
If one or more summary (s) are already defined, the selector appears in orange, with the types of summaries checked on the right.
The overview allows you to view all the objects in Jeedom, as well as their configuration :
