A widget is the graphic representation of an order. Each widget is specific to the type and subtype of the command to which it must be applied as well as the version from which Jeedom is accessed (desktop or mobile).
Before taking a look at the customization of widgets, let’s discover the possibilities offered by certain widgets present by default in the Core Jeedom.
The devices (or tiles) have certain configuration parameters accessible via the advanced configuration of the device, “Display” tab → “Optional parameters on the tile”.
col2 for devices in mobile version will allow doubling the width of the widget.This widget is a bit special because it is a multi-command widget, i.e. it assembles the value of several commands. Here he takes temperature and humidity commands. To configure it, you must assign the widget to the temperature and humidity controls of your equipment.
0.5, the widget will be 2 times smaller.IMPORTANT
It is ABSOLUTELY necessary that the generic types are indicated;Temperatureon the temperature control andHumidityon the humidity control (this is configured in the advanced configuration of the control, configuration tab).
NOTE
Attention on a design it is important not to put a command alone with this widget it will not work since it is a widget using the value of several commands, it is absolutely necessary to put the complete widget
This widget is used to display the content of an info / other command on several lines.
Widget for action / cursor control with button “+” and a button “-” allowing to act with precision on a value.
Widget for displaying water levels.
0.5, the widget will be 2 times smaller.1 to display the minimum and maximum values of the command.0.Regarding widgets for switches (on / off, turn on / off, open / close, etc…), it may be considered more visually pleasing to display only an icon reflecting the status of the device to be controlled.
This possibility can be used both with default widgets and with custom widgets.
To do so, it is necessary to take into account 2 prerequisites :
Example
Advice
Uncheck “Afficher” of the info / binary command which will not need to be displayed.
'on':'on',
'off':'off',
'monter':'on',
'descendre':'off',
'ouvrir':'on',
'ouvrirStop':'on',
'ouvert':'on',
'fermer':'off',
'activer':'on',
'desactiver':'off',
'disable':'off',
'lock':'on',
'unlock':'off',
'marche':'on',
'arret':'off',
'stop':'off',
'stop':'off',
'go':'on'
Trick
As long as the standardized name remains readable, it is possible to adapt the naming, for example open_volet Or shutter_close, walk_2 And stop_2, etc.
The Widgets page, accessible from the menu Tools → Widgets, allows you to add custom widgets in addition to those available by default in Jeedom.
There are two types of custom widgets :
You have four options :
In this part you will find all the widgets that you have created classified by type.
Trick
You can open a widget by doing :
Clickon one of them.Ctrl + ClickorClick + Centerto open it in a new browser tab.
The search engine allows you to filter the display of widgets according to different criteria (name, type, subtype, etc…). The Esc key cancels the search.
To the right of the search field, three buttons that can be found in several places in Jeedom:
Once on the configuration page of a widget, a context menu is accessible by `` Right Click ‘’ on the tabs of the widget. You can also use a Ctrl + Click or Click + Center to directly open another widget in a new browser tab.
Once on the page Tools → Widgets you have to click on the button “Add” and give a name to your new widget.
Afterwards :
To put it simply, it’s code (HTML / JS), integrated into the Core, some parts of which are configurable by the user via the graphical interface of the menu Widgets. From the same database and taking into account the elements that you will enter in the template, the Core will generate unique widgets corresponding to the display you want to obtain.
Depending on the type of widget, you can generally customize the icons, put the images of your choice and / or embed HTML code.
There are two types of template :
This is called a simple template, here you just have to say that the “On” matches such icon / image (using the choose button), THE “Off” to such other icon / image, etc…
The box Time-widget, if available, displays the duration since the last change of state under the widget.
For templates using images, you can configure the width of the widget in pixels depending on the support (Desktop width & Movable width). Different images can also be selected according to the active theme of Jeedom (light or dark).
Trick
For advanced users, it is possible to put tags in the replacement values and to specify their value in the advanced configuration of the command.
If, for example, in Desktop width you put as value#largeur_desktop#(be careful to put the#autour) puis dans la configuration avancée d’une commande, onglAnd affichage → “Paramètres optionnels widget” vous ajoutez THE paramètrelargeur_desktop(sans les#) and give it the value “90”, this custom widget on this command will be 90 pixels wide. This allows you to adapt the size of the widget to each order without having to make a specific widget each time.
This is called multistate templates (several states). Instead of putting an image for the “On and / or for the “Off as in the previous case, you will assign an icon according to the validation of a condition (test). If this is true then the widget will display the icon / image in question.
As before, different images can be selected depending on the theme active on Jeedom and the box Time-widget displays the duration since the last change of state.
The tests are in the form : #value# == 1, #value#will be automatically replaced by the current value of the command. You can also do for example :
#value# > 1#value# >= 1 && #value# <= 5#value# == 'toto'NOTE
It is essential to show the apostrophes (‘) around the text to compare if the value is text (info / other).
NOTE
For advanced users, it is also possible to use javascript functions such as#value#.match ("^ plop"), here we test if the text starts withplop.
NOTE
It is possible to display the value of the command in the widget by specifying#value#in the HTML code of the test. To display the unit add#unite#.
In code mode you have access to different tags for orders, here is a list (not necessarily exhaustive)) :
When a new value Jeedom will search in the page if the command is there and in Jeedom.cmd.update if there is an update function. If yes it calls it with a single argument which is an object in the form :
{display_value: '#state#', valueDate: '#valueDate#', collectDate: '#collectDate#', alertLevel: '#alertLevel#'}
Here is a simple example of javascript code to put in your widget :
<script>
jeedom.cmd.addUpdateFunction('#id#', function (_options) {
if (is_object(cmd = document.querySelector('.cmd[data-cmd_id="#id#"]'))) {
cmd.setAttribute('title', ': ' + _options.valueDate + '<br>: ' + _options.collectDate)
cmd.querySelector('.value').innerHTML = _options.display_value
cmd.querySelector('.unit').innerHTML = _options.unit
jeedom.cmd.refreshValue([{ cmd_id: '#id#', value: '#value#', display_value: '#state#', valueDate: '#valueDate#', collectDate: '#collectDate#', alertLevel: '#alertLevel#', unit: '#unite#' }])
</script>
Here are two important things :
The function is called during an update of the widget. It then updates the html code of the widget_template.
The call to this function for the initialization of the widget.
You will find here examples of widgets (in dashboard and mobile folders)
