The module
The Jeedom visual
Les télécommandes “Smile” ont un canal, elles sont idéales pour la table de chevet, salle de bain et surtout pour les enfants, car celles-ci sont très robustes grâce au matériau utilisé. Ultra simples et à la fois “fun” elles ont pour but d’être pratiques dans l’habitat. They exist in three different colors.
They are easily connected to the different receivers and can therefore control on / off lights, variable lights, shutters, gates, garage doors. Available in 3 colors.
In addition, interaction with other protocols is possible, it can interact with Edisio brand receivers, with Jeedom, but also by any Z-Wave receiver on your network.
Here is how the remote control works :
To replace the battery of your remote control, here is the procedure to follow :
The association of an Edisio transmitter is simple and automatic. Just press the button on your remote control.
Once, your associated equipment, you should get this :
Once your equipment is created, you should get the commands associated with the module :
Once your remote control is configured, you can with the Jeedom Scenario plugin, interact with your remote control on Jeedom and its equipment.
NOTE
The remote control with binary status feedback.
