info.json File Documentation
Included since version 3.0 of Jeedom, the file info.json is required for the plugins to function properly and to be deployed correctly on the Jeedom Market.
The info.json file is saved in the folder /plugin_info/ for your plugin.
List of variables in the file info.json
Fields marked with an * are required.
Fields Values
id * Unique identifier for the plugin on the Jeedom Market. Must begin with a letter. No accents. Cannot contain _
name * Plugin name.
description * Description of the plugin, as it will appear on the Jeedom Market. Minimum 80 characters. (<br/> for line breaks). Note that this is a table for the different languages supported by Jeedom (be sure to look closely at the example in the template plugin)
utilization Additional information to supplement the documentation on using the plugin.
licence * Type of license.
author * Name of the plugin author, as it will appear in the plugin’s information once the plugin is installed.
require * Minimum required version of Jeedom (Core).
os Minimum and maximum required Debian versions. Specified as a JSON object, for example: {“min”: 10, “max”: 12.99} (Core 4.4.15 minimum). If either field is left blank, it will not be compared to the user’s OS version. You can specify a more precise version, such as 10.5, for example. To remove the version restriction, you must republish the app on the marketplace with an empty value “”. Note that for the maximum value, it is recommended to use .99 to include all minor versions.
category * Plugin category on the Jeedom Market. It is essential to comply with the Legend for the table below
display If the plugin uses a dedicated panel on the desktop, this is the name of the panel’s main file.
mobile If the plugin uses a dedicated panel in the Jeedom web app, this is the name of the main file for that panel.
changelog * HTML link to the Changelog.
documentation * HTML link to the plugin’s documentation.
changelog_beta * HTML link to the Beta Changelog.
documentation_beta * HTML link to the plugin’s beta documentation.
link -> video HTML link to a presentation video.
link -> forum HTML link to the forum thread on the plugin’s official topic.
language List of languages available for the plugin: fr_FR, en_US, de_DE, it_IT, es_ES, pt_PT
compatibility Plugin compatibility: miniplus, smart, docker, rpi, diy, mobileapp, v4.
hasDependency “true” if The plugin must install dependencies, otherwise “false” or absent.
hasOwnDeamon “true” if The plugin must run daemons, otherwise “false” or absent.
maxDependancyInstallTime Maximum time allowed for installing the outbuildings, expressed in minutes.
specialAttributes Allows plugins to request additional setting on devices or users (be sure to look closely at the plugin template example) (See explanation below)
issue URL to the bug tracker (if external; if left blank, you will receive an email)
Example
File plugin-template/plugin_info/info.json
CATEGORY LIST
Jeedom Market info.json
Communication communication
Comfort wellness
Energy energy
Weather weather
Monitoring monitoring
Multimedia multimedia
Nature nature
Connected Objects devicecommunication
Organization organization
Home Automation Gateway home automation protocol
Programming programming
Home automation protocol automation protocol
Health health
Security security
Automation automatisation
SpecialAttributes
These attributes allow you to request additional settings from users for each object (objet as defined by Jeedom: Tools / Objects menu; typically, this represents the rooms in our home automation system) or for each user.
Usage
In your code, you can retrieve the values of these parameters using the object User for a User attribute, or the object jeeObject for an object attribute:
user : $user->getOptions(‹ plugin::ID_plugin::clef ›)
object : $jeeObject->getConfiguration(‹ plugin::ID_plugin::clef ›)
Object Attributes
The syntax for specifying two specific parameters per object is as follows:
	"specialAttributes" : {
		"object" : {
			"toto" : {"name" : {"fr_FR" : "Plop je suis un attribut spécial"},"type" : "input"},
			"toto2" : {"name" : {"fr_FR" : "Plop je suis un attribut spécial number"},"type" : "number"}
Users will be able to set these two parameters for each object in the object configuration menu (Tools / Objects menu). Here is some free-form text and a digital one. Object Attribute
User Attributes
		"user" : {
			"toto" : {"name" : {"fr_FR" : "Plop je suis un attribut spécial users"},"type" : "select","values" : [{"value" : "1", "name" : "valeur 1"},{"value" : "plop", "name" : "valeur plop"}]}
Here, this attribute allows each user to set their own preference (in the Settings / Preferences menu) User Attribute
EqLogic Attributes
	"specialAttributes": {
        "eqLogic": {
            "mqttTranmit": {
                "type": "checkbox",
                "name": {
                    "fr_FR": "Transmettre l'équipement en MQTT"
Here, this attribute allows you to set a parameter for each Jeedom device (in the device’s advanced settings). You can find it in the device’s settings under plugin::mqtt2::mqttTranmit (plugin::id_plugin::key)
