Here’s a tutorial on how to install VMware on an Intel NUC (Gen 6). Next, we’ll see how to add Jeedom to it
The Intel NUC is a small PC—not the most powerful, but very energy-efficient and compact. This makes it a perfect little VMware-based virtualization server.
There are currently two 6th-generation NUCs (the others also work with VMware but require additional drivers to be installed on the VMware kernel):
The i5 is significantly more powerful because it has a little more cache and, most importantly, a turbo mode that allows it to run at much higher clock speeds.
In addition, there are two types of control units:
That makes a total of 4 items:
You’ll also need to add an SSD and memory. For the SSD, I recommend 240 GB or more, unless you choose a model with a 2.5-inch drive bay (which lets you add an additional hard drive) or use a Synology-type NAS to set up an iSCSI LUN. Don’t forget that a basic VM (without storage) takes up between 20 and 40 GB; add 40 GB for VMware itself, and it fills up quickly.
VMware does not support adding USB drives, so it is difficult to expand the available storage space
Note: For memory, you absolutely must use DDR4 in 260-pin SO-DIMM form factor. You need at least 4 GB for VMware, but based on my experience, I recommend at least 8 GB (personally, I’ve even gone up to 16 GB; the NUC supports a maximum of 32 GB). In this case, there’s no specific memory recommendation—the cheapest option works just fine (note that I always buy packs of two modules, as this improves performance):
Before starting the actual installation, you’ll first need to download VMware and copy it to a USB flash drive.
If you install VMware 6.5, there’s an issue with the new USB management and Z-Wave dongles; to make it work, you need to apply this KB. Please note that this procedure is no longer necessary in VMware 6.7
I actually think this is the hardest part. To make your life easier, you need to:
Right above that, you’ll also find your license key—you might as well grab it while you’re there.
This is much simpler—just click the. Next, you need to run the .exe file
This is easy, too—here’s how to set up Rufus:
All you have to do is click “Start” and wait.
Here are the three components for my NUC:
The NUC box:
To open it:
Components taken out of their boxes:
Opening the NUC is very simple: turn it upside down, unscrew the four screws under the feet (they won’t come out completely—that’s normal; you just need to unscrew them), then pull slightly on the screws to open the NUC:
With the SSD installed (on the left), the screw at the end to secure it is a bit of a hassle to put back in—luckily, you only have to do this once
Installing the memory (on the right):
There you go—you can close it up now (unless, of course, you’ve opted for a 2.5-inch SSD, in which case you’ll need to insert it into the cover).
It’s very simple: just plug the USB flash drive into one of the NUC’s USB ports, connect a monitor to the HDMI port, a keyboard, and the power supply. Turn on the NUC, and the installation will start automatically:
I forgot to take screenshots of the license validation; you just need to agree by following the instructions
Here, be sure to select the drive that corresponds to the SSD (you can identify it either by its name or by its size)
Select “French”:
Set a password. To start with, I recommend using something simple like “oooo” (we’ll change it later):
Press F11 to confirm:
Installation will take 10 to 20 minutes. Afterward, you’ll need to remove the USB drive and wait for the system to reboot.
Once the reboot is complete, you should have:
There you go—VMware is installed (and it’s nice because it gives you its IP address), so now it’s time to play around with it!!!
Next, here is a tutorial for setting up your first VM. And you’ll find here A tutorial on tips and tricks (for example, how to enter your VMware license)
