The module
Placed in a corridor, the living room, the garage of your house for example, the motion sensor detects a presence, the change of state is instantaneous.
Thanks to its wide viewing angle and its range, it makes it possible to secure a large perimeter. Integrated LED indicator signals any change of state.
Placement is recommended at a height of 150 cm and near the desired felt temperature.
You will find the button “E” which is the association button of the temperature sensor.
The sensor detects the slightest movement within a radius of about 6m
By default, the timer is disabled. This parameter is used to configure the delay :
The association of the motion sensor is easy as pie. Just press the “E” button, located under the sensor. This will be recognized automatically by Jeedom. Just go to the Edisio plugin. You will be able to place it in an object, give it a name and save.
Once your equipment is paired, you should get this :
So that the widget is present on the dashboard, remember to place your equipment in an object.
Once your equipment is created, you should get the commands associated with the module :
