The module
The Jeedom visual
Placed on a door, window, garage door, drawer, all opening, this compact and discreet sensor will allow you to know the opening or closing state of the latter.
Depending on the state, the sensor controls the switching on or off of your lights, closing or opening of the shutters, or even the triggering of an alarm via a scenario.
The signal is only sent when the sensor is separated from its magnetic element. Integrated LED indicator signals any changes in state. Low battery level signaled by 3 audible “beeps” on the receiver
You will find below the button “E” which is the association button of the temperature sensor.
By default, the sensor is configured in NO (Normally Open)
NOTE
You will therefore have to configure your sensor, if you want to have a widget with a door closed when it is.
Pairing the motion sensor is easy. Just press the “E” button, located under the sensor. This will be recognized automatically by Jeedom. Just go to the Edisio plugin. You will be able to place it in an object, give it a name and save.
Once your equipment is paired, you should get this :
So that the widget is present on the dashboard, remember to place your equipment in an object.
Once your equipment is created, you should get the commands associated with the module :
