Edisio ETC1
The module
etc1.module 1
etc1.module 2
The Jeedom visual
etc1.vue default
Summary
Les télécommandes “Smile” ont un canal, elles sont idéales pour la table de chevet, salle de bain et surtout pour les enfants, car celles-ci sont très robustes grâce au matériau utilisé. Ultra simples et à la fois “fun” elles ont pour but d’être pratiques dans l’habitat. They exist in three different colors.
They are easily connected to the different receivers and can therefore control on / off lights, variable lights, shutters, gates, garage doors. Available in 3 colors.
In addition, interaction with other protocols is possible, it can interact with Edisio brand receivers, with Jeedom, but also by any Z-Wave receiver on your network.
Fonctions
Technical characteristics
etc1.dimmension
Module data
General configuration
Function diagram
Here is how the remote control works :
etc1.diagramme
Battery replacement
To replace the battery of your remote control, here is the procedure to follow :
etc1.remplacement pile
Association of the remote control with Jeedom
The association of an Edisio transmitter is simple and automatic. Just press the button on your remote control.
Commands
Once, your associated equipment, you should get this :
etc1.general
Commandes
Once your equipment is created, you should get the commands associated with the module :
Commands
Informations
Commands
Utilisation
Once your remote control is configured, you can with the Jeedom Scenario plugin, interact with your remote control on Jeedom and its equipment.
NOTE
The remote control with binary status feedback.
