The module
The Jeedom visual
The e-Trendy 4-channel mini remote control is simple, robust and design, it was created to please. It easily connects to receivers and can control your On / Off and dimmable lights, motors, blinds, shutters, gates, garage doors. It has two programming modes.
In addition, interaction with other protocols is possible, it can interact with Edisio brand receivers, with Jeedom, but also by any Z-Wave receiver in your network.
To have Jeedom automatically create your transmitter modules, remember not activate the option in the plugin configuration.
Control and centralize your On / Off lights and dimmers, opening, motors, on the same key or on 2 separate buttons. The e-Trendy remote controls have 2 operating modes, MODE 1 and MODE 2 :
Depending on whether your transmitter is configured in “1 key” or “2 keys” mode, here is how the remote control works :
The association of an Edisio transmitter is done simply and automatically. Just press any key you want on your Jeedom.
Once, your associated equipment, you should get this :
Once your equipment is created, you should get the commands associated with the module :
Once your remote control is configured, you can with the Jeedom Scenario plugin interact with your remote control on Jeedom.
NOTE
Each key to a binary status return.
How to delete the association of a key with a receiver ?
Press 5 seconds on the “R” of the receiver, a simple beep signals the active programming mode. Press the “C” key to delete. Repeat this operation for all the keys to be erased.
