The module
The Jeedom visual
Placed in a room, the desired room temperature will automatically rise. In addition, associated with an EMR-2000 or EDR-B4 type receiver (4 outputs) you will have a thermostat connected and controllable from anywhere in the world through the internet.
The signal is only sent after detecting a temperature difference of 0.5 ° C or 1 ° C or every 5 minutes. In addition, the sensor is compact and discreet.
Integrated LED indicator signals any change of state.
Placement is recommended at a height of 150 cm and near the desired felt temperature.
You will find below the button “E” which is the association button of the temperature sensor.
By default, the temperature delta is programmed at 1 ° C (+/- 10%) in order to optimize the battery life. You can adjust this parameter:
The combination of the temperature sensor is a breeze. Just press the “E” button, located under the sensor. This will be recognized automatically. Place it in an object, give it a name and save.
Once, your associated equipment, you should get this :
Once your equipment is created, you should get the commands associated with the module :
