The plugin ** **). . :
!alt text](../images/image.png)
!alt text](../images/accueil_config_equip.png)
!alt text](../images/image-1.png) .
It is important on the right side to choose the type of equipment. This is what will allow us to know how to parse the frame.
: !alt text](../images/equiplorawanconfig.png)
Once done you can save. Following this, the next time you receive a frame, the commands for your equipment will update
Some Lorawan modules have Action commands which can be used to send instructions to the modules via the Jeedom interface.
In the LoraPayload plugin’s Equipment tab :
Remplacer: js ) {
Remplacer: js ) {
: js = { Decode, Encode }
/var/www/html/plugins/lorapayload/core/config/devices/ .js).:
json
“name”: “
“groupe”: “
“configuration”: {
“type”: “”,
“language”: “)
“deviceProfile”: “)
“commands”:
“name”: “
“type”: “)
“subtype”: “
“isVisible”:
“isHistorized”:
“unite”: “
“logicalId”: “parsed::)
“name”: “
“type”: “info”,
“subtype”: “numeric”,
“isVisible”: 0,
“isHistorized”: 0,
“unite”: “”,
“logicalId”: “
“name”: “Reboot”,
“type”: “)
“subtype”: “other”,
“isVisible”: 1,
“logicalId”: “encoder::reboot::::
type: .
language: .
deviceProfile: ).
info: ).
action: ).
numeric: .
string: .
binary: .
other: .
: parsed::nom_de_la_variable (.)
json
action::
ou
json
encoder::
ou
encoder::
(: slider)
: "logicalId": "payload"
: : decoded.temperature ⇒ "parsed::temperature").
Regardez le tableau la section “ downlink” “ via payload”,
| 0: : | ||
| 1: : … | ||
json { “”: { “enable”: 1, “”: 2, “”: 30, “”: 40 } }
. !alt text](../images/ongletintegrationmass.png) ** : ** :
. !alt text](../images/tableaupostanalyse.png)
!alt text](../images/image-11.png)
!alt text](../images/image-13.png) . . !alt text](../images/image-12.png) . .
Access path :
→ rak10701 files.csv and rak10701_history.json. !alt text](../images/rak3.png)
If write permission is not granted, restore the folder and file permissions in the OS/DB field in configuration.
!alt text](../images/rak4.png)
