Plugin for using the Jeedom Mobile application.
The Jeedom mobile application requires the installation of this plugin so that the box can communicate with the Mobile application.
After installing the plugin, you just need to activate it :
To connect your phone : there are 2 possible methods; on the first screen of the application, you are offered to connect your market account, and thus find all the boxes associated with this account, or simply add a box.
To benefit from the application’s functionalities, the core of your Jeedom must be in 4.4.0 minimum
All you have to do is enter your Market ID and password.
Several choices on this screen :
You enter the url of your Jeedom (internal or external), as well as the access identifiers to it and you confirm with the LOGIN button
You click on QR Code : a new screen appears; you can scan a QRCode from the Mobile plugin of the box you want to add, via the QRCODE tab of the plugin.
Qr Code tab of the Mobile plugin
Once this first step has been completed, you are registered in the application: if you have the Mobile plugin, you will have access via the menu to Notifications, QrCodes, Menu customization ….
In the menu, you will have a Boxs tab, which groups together all the boxes present on this market account
Simply click on the box where the Mobile plugin is installed, then identify yourself to access the box.
The box will go to the top of the list, having validated its authentication. You can do this for several boxes.
You can also click on the + button at the bottom right to access different options;
To access features such as Notifications, Menu Personalization or Geolocation, you must first have selected at least one current box’
We add a Geolocation zone by clicking on the + icon
We type the address we are looking for, we validate with Enter on his phone; the cursor will then position itself on the desired address. We can then add a name and save the zone.
This will create a new command on your mobile equipment, of binary type, which will correspond to the entries and exits of the zone if geolocation is activated on your mobile phone.
We can also change the radius of the zone, to extend the detection of the zone.
I have problems with notifications
This part is currently being improved and optimized on the beta application.
I have problems displaying my webview
On your Jeedom, in the Preferences, check that the mobile home page is HOME.
Setup
To configure the plugin, you must add the phones that will be able to access Jeedom.
To Add a phone : Plugins → Communication → App Mobile → Add
Here are the parameters to enter :
The choice of the user is important because it determines the equipment to which he will have access according to his rights.
After saving, you will get a QRCode allowing the application to configure itself.
After the initialization of the Mobile Plugin you have the possibility to modify the generic types of orders, plugins and parts.
By clicking on a plugin, you can authorize it or not to chat with the mobile application, and configure each of the generic types associated with its commands.
By clicking on a part, you can authorize it or not to be present in the mobile application, and configure each of the generic types associated with its orders.
You will find the applications on the mobile blinds :
Android Google Play
Apple App Store
When you launch the Mobile application for the first time, you will be offered a tutorial to help you configure it.
After downloading and installing your Jeedom mobile application, launch the application on your smartphone.
You then arrive in a configuration tutorial which we advise you to follow. Some steps have been done previously.
You will then have the choice between a manual or automatic configuration by QRcode. If you choose to configure by QRcode, just flash the QRcode present on the Mobile App plugin in the smartphone equipment created previously. In this case, the application will automatically recover all the configuration of your Jeedom and connect automatically. When it is connected to your home via Wifi, the application will automatically use the Jeedom ethernet address internal to your network. When you are connected in 4G or 3G, it will use your external address to connect to your Jeedom (for example via the Jeedom DNS service if you use it). If you choose manual configuration, in this case you will need to manually enter the internal and external IP addresses of your Jeedom. This option is reserved for an informed public.
The application will synchronize and you will arrive on its home page (preceded by a mini presentation guide).
Jeedom mobile app is now ready to work.
On the application you can have Favorites (shortcuts of commands, plugins, scenarios).
Here is the procedure for creating them :
Click on one of the + on the home screen of the application :
You will arrive on the shortcut type selection page :
For example, we are going to take Action, so it offers us Coins / Objects :
Then simply select the action you want as a shortcut :
It is then possible to personalize the color of this one (for the moment three colors are proposed) :
As well as the two associated texts :
Here, you have now a shortcut of your order (in version 1.1 On / Off commands are expected to appear on the same key).
Better than words, here is an example of the generic credits for a light with all its controls (see also the Light table below) :
| Picture | Type generic | Dev plugin part | Description |
Light Button OnButton Off Light |
LIGHT_ONLIGHT_OFF |
presence of two buttons “ON” and “Off” no status feedback. |
Light Button OnButton Off LightState Light |
LIGHT_ONLIGHT_OFFLIGHT_STATE |
Status feedback present, the left button toggles between on and off |
Light Toggle ButtonState Light |
LIGHT_TOGGLELIGHT_STATE |
Light Button OnButton Off LightState LightLight Slider |
LIGHT_ONLIGHT_OFFLIGHT_STATELIGHT_SLIDER |
Status feedback present, the left button allows to switch between On and Off and the slider allows to control the intensity |
Light Button OnButton Off LightState LightLight SliderLight Color (info)Light Color (action)Light Mode (optional, it is used to have light modes, for example rainbow on Hue philips) |
LIGHT_ONLIGHT_OFFLIGHT_STATELIGHT_SLIDERLIGHT_COLORLIGHT_SET_COLORLIGHT_MODE |
Status feedback present, the left button allows to switch between On and Off and the slider allows to control the intensity. In the circle the color of the lamp is present and when you click it you can change the color and activate a mode |
Socket Button OnButton Off socket |
ENERGY_ONENERGY_OFF |
Socket Button OnButton Off socketState Taking |
ENERGY_ONENERGY_OFFENERGY_STATE |
Socket Button OnButton Off socketState TakingSlider socket |
ENERGY_ONENERGY_OFFENERGY_STATEENERGY_SLIDER |
Mount Button PaneDown button paneStop Button PaneState pane (optional) |
FLAP_UPFLAP_DOWNFLAP_STOPFLAP_STATE (optional) |
Presence of three buttons “Up”, “Down”, “Stop”, optional status feedback. |
Mount Button PaneDown button paneStop Button PaneState paneSlider Button Pane |
FLAP_UPFLAP_DOWNFLAP_STOPFLAP_STATEFLAP_SLIDER |
Presence of a slider, with an Up / Down button in Toggle (with status icon) |
InnondationTEMPERATURE (optional)Humidity (optional)SABOTAGE (optional) |
FLOODTEMPERATURE (optional)HUMIDITY (optional)HUMIDITY (optional) |
Allows you to have your complete flood sensor on a single line. |
State LockOpen Button LockLock Button Close |
LOCK_STATELOCK_OPENLOCK_CLOSE |
Siren StateSiren Button OnSiren Button Off |
SIREN_STATESIREN_ONSIREN_OFF |
SmokeTEMPERATURE (optional) |
SMOKETEMPERATURE (optional) |
Allows you to have your complete smoke sensor on a single line. |
TEMPERATUREHumidity (optional) |
TEMPERATUREHUMIDITY (optional) |
See picture. |
PRESENCETEMPERATURE (optional)Brightness (optional)Humidity (optional)UV (optional)SABOTAGE (optional) |
PRESENCETEMPERATURE (optional)BRIGHTNESS (optional)HUMIDITY (optional)UV (optional)SABOTAGE (optional) |
See picture. |
Door/WindowTEMPERATURE (optional) |
OPENING / OPENING_WINDOWTEMPERATURE (optional) |
See Image (i.e. you can choose between window and door). |
Pilot wire heating ON buttonHeating pilot wire OFF buttonHeating pilot wire StateButton pilot wire heating (optional) |
HEATING_ONHEATING_OFFHEATING_STATEHEATING_OTHER |
The ON / OFF and Status buttons allow you to create the button on the far left of the template and the button pilot wire heating are there to add buttons (5 max) |
Generic Action |
GENERIC_ACTION |
The button takes the form of the action type. By default it’s a toggle, if it’s a message then you have an envelope, if slider you have a slider etc… |
Generic Information |
GENERIC_INFO |
The button takes the form of the type of information. |
I am on Android version of the app (1.0.1 or 1.0.0) I cannot access my parts or even the configuration of the app.
You had a popup warning you of a concern about the accessibility settings, so you just have to go to the accessibility settings of your mobile and uncheck the applications using this option. (A fix will be brought soon on the app)
I have a message in one of the lines of my modules telling me that it missing a Generic Type !
By reading this message, it tells you what generic type is missing to create a compatible template. Just apply it.Refer to the doc chapter Generic Type.
I have a problem with one of the plugins called fully integrated (weather, thermostat, alarm, camera) !
Do not hesitate to access your module and click on save again, this will re-include the generic types associated with the module.
Unable to put an info on the welcome of the app !
This is normal, it will be available on version 1.1.
I have the application which takes up a lot of memory in my Phone !
There was a bug on versions 1.0.0 and 1.0.1 on the Camera part. The problem will not happen again with 1.0.2, to delete the cache without overpricing the app, simply go to the configuration of your Mobile App and click on “delete the cache”.
I have a concern of first synchronization on the app or of sql on the mobile plugin !
You have to put generic types and authorize the plugin to send generics see the doc a little higher.
