The JeeDashboardPublish Plugin allows you to publish values from Jeedom using the jMQTT plugin.
It is necessary to enter the MQTT Broker parameters.
It is possible to create as much equipment as you want :
It is recommended to enter a prefix in order to have unique names with two methods :
A hard prefix.
Using a Jeedom variable. It is necessary to check the box “Is a Jeedom variable” and enter the name of the variable : variable(xxx)
It is possible to enter the names of the commands to be published by selecting a list of commands with the “Choose commands” button or by adding manually with the “Add telemetry” button”.
It is possible to export the histories of one or more orders by specifying a start date.
