Nabaztag plugin
Plugin to order the Nabaztag.
Equipment configuration
Once the plugin is installed and activated from the Market, you access the Nabaztag plugin page by :
Here you find all your Nabaztag equipment :
Once an equipment is selected you get :
Here you find all the configuration of your equipment :
- Name of the Nabaztag equipment : name of your Nabaztag equipment
- Parent object : indicates the parent object to which the equipment belongs
- Category : equipment categories (it can belong to several categories)
- Activate : makes your equipment active
- Visible : makes it visible on the dashboard
- Address (openjabnab.fr or @IP) : openjabnab or IP (DNS) address of your openjabnab if you self-host it
- MAC address : your rabbit’s mac address (see below)
- API Token Purple : API token (see below)
Below you find the list of orders :
- the name displayed on the dashboard
- Pin up : allows to display the data on the dashboard
- advanced configuration (small notched wheels) : displays the advanced configuration of the command (logging method, widget, etc.)
- Test : Used to test the command
The list of commands is as follows :
- Standing : Wakes up the rabbit
- Restart : Restart the rabbit
- Sleep : Lets tell the rabbit to go to bed
- Air quality : Gives air quality (requires activation of the corresponding plugin in openjabnab)
- Ephemeris : Give ephemeris (requires activation of the corresponding plugin in openjabnab)
- Talking clock : Give the time (requires activation of the corresponding plugin in openjabnab)
- Weather : Gives the weather (requires activation of the corresponding plugin in openjabnab)
- Saying : Give a saying (requires activation of the corresponding plugin in openjabnab)
- Left ear : Allows you to choose the position of the left ear (16 positions possible)
- Right ear : Allows you to choose the position of the right ear (16 possible positions)
- Speak : Lets say a sentence to the rabbit
Retrieve max address and token
Go to the site openjabnab then log into your account :
Click on rabbit :
Then click on API :
Here activate the purple and public API and get the mac address as well as the purple API key to put it in the configuration of your rabbit on Jeedom
