This page allows you to gather on a single page the different elements configured on his Jeedom. It also gives access to functions of organization of equipment and controls, at their advanced configuration as well as configuration possibilities d’affichage.
This page is accessible by Tools → Home automation summary.
On the top of the page, we find : * Number of objects : Nombre total of objects configured in our Jeedom, counting the elements Inactive. * Number of equipments : Ditto for the equipment. * Number of orders : Ditto for orders. * Inactive : Check this box if you want the inactive items to be well displayed on this page. * Search : Search for a particular element. It can be the name of an equipment, an order or the name of the plugin by which the equipment was created.
You also have a button "History of deletions" which will allow you to display the history of orders, equipment, objects, view, design, deisgn 3d, scenario and deleted user.
Below there is one frame per object. In each frame, we find the list of equipment (in blue) which have this object as parent. The first frame No represents equipment that has no affected parent. For each object, next to its label, three buttons are available. From left to right :
The first is used to open the object configuration page in a new tab,
the second provides some information on the object,
the last allows you to display or hide the list of equipment attributed to him.
The background color of the object frames depends on the color chosen in object configuration.
By clicking / dropping on the equipment, you can change their order or even assign them to another object. It is from order established in this page that the dashboard display is calculated.
On each equipment we find :
A check box to select the equipment (you can select multiple). If at least one device is selected you have action buttons that appear at the top left for remove, return Jeedom/Invisible, active/Inactive selected equipment.
The last name equipment.
The Type equipment : Identifier of the plugin to which it belongs.
Inactive (small cross) : Means that the equipment is inactive (if it is not there, the equipment is active).
Invisible (crossed eye) : Means that the equipment is invisible (if it is not there, the equipment is visible).
External link (square with arrow) : Lets open in a new tab the equipment configuration page.
Advanced configuration (toothed wheel) : opens the advanced equipment configuration window.
List of commands (the arrow) : allows you to expand the list of commands (on orange background).
If you expand the command list, each orange block corresponds to an order for your equipment (a new click on the small arrow equipment can hide them).
If you double-click on the order or click on the small notched wheel this will bring up its configuration window.
It is possible to access (if the plugin supports it) directly to this window from the equipment configuration page in clicking on the advanced configuration button
The window of Advanced equipment configuration allows the edit. First, at the top right, some buttons available :
Connections : Displays the links of the equipment with the objects, commands, scenarios, variables, interactions… in the form graphic (in this one, a double click on an element brings you to its configuration).
Log : displays the events of the equipment in question.
Information : displays the raw properties of the equipment.
Save : Save the modifications made on equipment.
Remove : Remove equipment.
The tab Information contains the general information of the equipment and its controls :
Id : Unique identifier in the Jeedom database.
Last name : Name of equipment.
Logical ID : Logical equipment identifier (can to be empty).
Object ID : Unique identifier of the parent object (can to be empty).
Creation date : Equipment creation date.
Activate : Check the box to activate the equipment (don't forget to save).
Jeedom : Check the box to make the equipment visible (without forget to save).
Type : Identifier of the plugin by which it was created.
Failed attempt : Number of communications attempts consecutive with failed equipment.
Date of last communication : Date of last equipment communication.
Last update : Date of last communication with equipment.
Tags : equipment tags, to be separated by ‘,’. It allows on the dashboard to make personalized filters
Below you will find a table with the list of commands for the equipment with, for each, a link to their configuration.
In the tab Viewing, you will be able to configure some display behavior of the tile on the dashboard, the views, the design as well as mobile.
Jeedom : Check the box to make the equipment visible.
Show name : Check the box to display the name of equipment on the tile.
Display object name : Check the box to display the name of the parent object of the equipment, next to the tile.
Background color : Check the box to keep the background color by default (depending on the category of your equipment, see Administration → Settings → Colors). If you uncheck this box, you can choose another color. You can also check a new box Transparent to make the transparent background.
Opacity : Opacity of the background color of the tile.
Text color : Check the box to keep the color of the default text.
Borders : Check the box to keep the default border.
Otherwise, you have to put CSS code, property border (ex :
3px blue dashed for a dotted border of 3px in blue).
Rounded edges (in px) : Check the box to keep
the default rounding. Otherwise, you must put CSS code, property
border-radius (ex : 10px)
Below, we find optional display parameters that we can apply to equipment. These parameters are composed of a name and a value of. Just click on Add to apply one new. For equipment, only the value style is for the moment used, it allows to insert CSS code on the equipment in question.
Do not forget to save after any modification.
This part allows you to choose between the standard arrangement of commands (side by side in the widget), or in table mode. There is nothing to set in default mode. Here are the options available in mode Board :
Number of lines
Number of columns
Center in boxes : Check the box to center the commands in the boxes.
General style of boxes (CSS) : Allows you to define the style general in CSS code.
Table style (CSS) : Allows you to define the style of the table only.
Below for each box, the detailed configuration It allows you to this :
Box text : Add text in addition to the command (or all alone, if there is no order in the box).
Case style (CSS) : Change the specific CSS style of the box (beware this overwrites and replaces the general CSS boxes).
In a box in the table, if you want to put 2 commands one in below the other, don't forget to add a return to the line after the premiere in the Advanced configuration of it.
This tab provides information on the battery of the equipment and define alerts in relation to it. Here are the types of information that can be found :
Battery type,
Latest feedback,
Remaining level, (if of course your equipment works on battery).
Below, you can also define specific alert thresholds for battery for this equipment. If you leave the boxes empty, those are the default thresholds that will be applied.
You can also manage the timeout, in minutes, of the equipment. Through example, 30 tells jeedom that if the equipment has not communicated for 30 minutes, then you have to put it on alert.
The global parameters are in Administration → Configuration → Logs (or Facilities)
Allows you to write a comment about the equipment (date of changing the battery, for example).
Test : Used to test the command.
Connections : Displays the links of the equipment with the objects, commands, scenarios, variables, interactions…. under graphic form.
Log : Displays the events of the equipment in question.
Information : Displays the raw properties of the equipment.
To apply to* : Apply the same configuration on multiple orders.
Save : Save changes made to equipment
In a graph, a double click on an element brings you to its d’actualité.
NOTE
Depending on the type of order, the information / actions displayed can change.
The tab Information contains general information about the ordered :
Id : Unique identifier in the database.
Logical ID : Logical identifier of the command (can to be empty).
Last name : Name of the order.
Type : Type of command (action or info).
Subtype : Command subtype (binary, digital, etc.)).
Direct url : Provides the URL to access this equipment. (click right, copy the link address) The URL will launch the command for a Action and return the information for a Info.
Unit : Control unit.
Command triggering an update : Gives the identifier of a other command which, if that other command changes, will force the update of the displayed order.
Jeedom : Check this box to make the command visible.
Follow in the timeline : Check this box to have this command is visible in the timeline when it is used.
Prohibit in automatic interactions : forbids them automatic interactions on this command
Icon : Allows you to change the command icon.
You also have three other orange buttons underneath :
This command replaces the ID : Replace an ID of order by the order in question. Useful if you have deleted a equipment in Jeedom and you have scenarios that use commands from it.
This command replaces the command : Replace an order with the current command.
Replace this command with the command : The reverse replaces the order by another order.
NOTE
This kind of action replaces commands all over Jeedom (scenario, interaction, command, equipment….)
Below, you will find the list of different equipment, commands, scenarios, or interactions that use this command. A click on it to go directly to their configuration respective.
Calculation and rounding
Algorithm (#value# for value) : Allows make an operation on the value of the order before Jeedom treatment, example : ``#value# - 0.2` to entrench 0.2 (offset on a temperature sensor).
Rounded (number after decimal point) : Lets round the order value (Example : put 2 to transform 16.643345 in 16.64).
Generic type : Allows you to configure the generic type of the command (Jeedom tries to find it by itself in auto mode). This information is used by the mobile application.
Action on value, if : Lets make kinds of mini scenarios. You can, for example, say that if the value is worth more than 50 for 3 minutes, then you have to do such action. it allows, for example, to turn off a light X minutes after it is lit.
Historical
Historicize : Check the box to have the values for this order be recorded. (See Analysis → History)
Smoothing mode : Mode of smooth or d’archiving allows you to choose how to archive the data. By default, it's a average. It is also possible to choose the Maximum, The Minimum, or No. No Allows tell Jeedom that it should not archive on this order (both during the first 5 min period and with the archiving task). This option is dangerous because Jeedom keep everything : so there is going to be a lot more stored data.
Purge history if older than : Lets say to Jeedom to delete all data older than one certain period. May be handy for not keeping data if it is not necessary and therefore limit the quantity of information recorded by Jeedom.
Values management
Prohibited value : If the command takes one of these values, Jeedom ignores it before applying it.
Status return value : Returns the command to this value after a while.
Duration before return of status (min) : Time before return to value above.
Other
Management of the repetition of values : In automatic if the command goes up 2 times the same value in a row, then Jeedom will not take into account the 2nd ascent (avoid triggering several times a scenario, unless the command is to binary type). You can force the value to repeat or ban it completely.
Push URL : Allows you to add a URL to call in case of
order update. You can use tags
next : #value#`for the value of the order,`#cmd_name#
for the name of the command, #cmd_id#for the unique identifier
of the command, #humanname#for the full name of the command
(Ex : ``#[SalThe de bain][Hydrometrie][Humidité]#),#eq_name#`for the name of the equipment
Confirm action : Check this box for Jeedom to request confirmation when the action is launched from the interface of this command.
Access code : Allows to define a code that Jeedom will ask when the action is launched from the interface of this command.
Action before execution of the command : Allows you to add orders before each execution of the order.
Action after execution of the order : Allows you to add orders after each execution of the order.
Allows you to define an alert level (Warning or Danger) en
depending on certain conditions. For example, if value> 8 for 30
minutes then the equipment can go on alert Warning.
NOTE
On the page Administration → Configuration → Logs, you can configure a message type command that will allow Jeedom to get you warn if the warning or danger threshold is reached.
In this part, you will be able to configure certain behaviors display of the widget on the dashboard, views, design and mobile.
Widget : Allows you to choose the widget on dekstop or mobile (at note that you need the widget plugin and you can do that too from it).
Jeedom : Check to make the command visible.
Show name : Check to make the name of the command, depending on the context.
Display name and icon : Check to make the icon visible in addition to the name of the command.
Wrapped line before widget : Select before widget or after the widget to add a line break before or after the widget (to force for example a display in column of different equipment commands instead of lines By default)
Below, we find optional display parameters that we can switch to widget. These parameters depend on the widget in question, so you have to look at his card on the Market to know them.
Allows you to modify the widget code just for the current command.
NOTE
If you want to modify the code don't forget to check the box Enable widget customization
