The interaction system in Jeedom makes it possible to carry out actions to from text or voice commands.
These orders can be obtained by :
SMS : send an SMS to launch commands (action) or ask a question (info).
Cat : Telegram, Slack, etc.
Vocal : dictate a phrase with Siri, Google Now, SARAH, etc. For launch commands (action) or ask a question (info).
D’informations sont indispensables à la bonne compréhension de : launch an HTTP URL containing the text (ex. Tasker, Slack) To launch commands (action) or ask a question (info).
The interest of interactions lies in the simplified integration in other systems like smartphone, tablet, other home automation box, etc.
To access the interaction page, go to Tools → Interactions :
At the top of the page, there are 3 buttons :
Add : which allows to create new interactions.
Regenerate : which will recreate all the interactions (maybe très long > 5mn).
Test : which opens a dialog for writing and test a sentence.
If you have an interaction that generates the sentences for the lights for example and you add a new command module of light, you will either have to regenerate all the interactions, or go to the interaction in question and save it again for create the sentences for this new module.
The principle of creation is quite simple : we will define a sentence generator model which will allow Jeedom to create one or more hundreds of other sentences that will be possible combinations of the model.
We will define responses in the same way with a model (this allows Jeedom to have several answers for a single question).
We can also define a command to execute if for example the interaction is not linked to an action but to information or if we wish to carry out a specific action after it (it is also possible to execute a scenario, to control several commands…).
The configuration page consists of several tabs and buttons :
Sentences : Displays the number of sentences in the interaction (one click above shows them to you)
Save : records the current interaction
Remove : delete current interaction
Duplicate : duplicate the current interaction
Last name : name of the interaction (can be empty, the name replaces the request text in the interaction list).
Group : interaction group, it helps organize them (can be empty, so will be in the group “none”).
Active : allows to activate or deactivate the interaction.
Request : The generating model sentence (required).
Synonymous : allows to define synonyms on names some orders.
Reply : the answer to provide.
Wait before answering (s) : add a delay of X seconds before generating the response. It allows for example to wait for the return of a lamp status before being answered.
Binary conversion : converts binary values to open / closed for example (only for type commands binary info).
Authorized users : limits interaction to certain users (logins separated by |).
Limit to type commands : allows to use only the types of actions, info or both types.
Limit to orders with subtype : allows to limit generation to one or more subtypes.
Limit to orders with unit : allows to limit the generation with one or more units (Jeedom creates the list automatically from the units defined in your orders).
Limit to orders belonging to the object : allows to limit generation to one or more objects (Jeedom creates the list automatically from the objects you created).
Limit to plugin : limits generation to one or more several plugins (Jeedom automatically creates the list from plugins installed).
Limit to category : limits generation to one or more categories.
Limit to equipment : limits generation to one single equipment / module (Jeedom automatically creates the list at from the equipment / modules you have).
Use if you want to target one or more specific commands or pass particular parameters.
NOTE
The screenshots may be different in view of developments.
The easiest way to set up an interaction is to use it give a rigid generator model, without possible variation. This method will target a command or a scenario very precisely.
In the example which follows, we can see in the field "Request" the sentence exact to provide to trigger interaction. Here, to turn on the living room ceiling light.
We can see, on this capture, the configuration to have a interaction linked to a specific action. This action is defined in the "Action" part of the page.
We can very well imagine doing the same with several actions to turn on several lamps in the living room as the following example :
In the 2 examples above, the model sentence is identical but the resulting actions change depending on what is configured in the "Action" part, we can therefore already with a simple interaction to single sentence imagine combined actions between various commands and various scenarios (we can also trigger scenarios in the game action of interactions).
To add a scenario, create a new action, write “scenario” without an accent, press the tab key on your keyboard to bring up the scenario selector.
Here we will see all the interest and all the power of interactions, with a model sentence we will be able to generate sentences for a whole group of commands.
We will resume what was done above, delete the actions that we had added, and instead of the fixed sentence, in “Request”, we will use the tags #commande# and #equipement#. Jeedom will replace these tags with the name of the commands and the name of equipment (we can see the importance of having names of consistent control / equipment).
So we can see here that Jeedom generated 152 sentences from our model. However, they are not very well built and we has a little bit of everything.
To make order in all this, we will use the filters (part right of our configuration page). In this example, we want generate sentences to turn on lights. So we can uncheck the command type info (if I save, I only have 95 sentences left generated), then, in the subtypes, we can only keep checked “default “which corresponds to the action button (so only 16 remain phrases).
It's better, but we can make it even more natural. If I take the generated example "On entry", it would be nice to be able to transform this sentence in “turn on the entry” or in “turn on the entry”. To do that, Jeedom has, under the request field, a synonymous field which will allow us to name orders differently in our "generated" sentences, here it is "on", I even have "on2" in the modules which can control 2 outputs.
In synonyms, we will therefore indicate the name of the command and the (s) synonym (s) to use :
We can see here a somewhat new syntax for synonyms. A name can have several synonyms, here "on" has as synonym “turn on “and” turn on”. The syntax is therefore “Name of the order” = “synonym 1“, “synonym 2” (we can put as many synonym that we want). Then, to add synonyms for another command name, just add after the last synonym a bar vertical “|” after which you can again name the command which will have synonyms like for the first part, etc.
It's already better, but it is still missing for the “on” “input command” the "l" and for others the "the" or "the" or "a", etc. We could changing the name of the equipment to add it would be a solution, otherwise we can use variations in demand. It consists of list a series of possible words at a location in the sentence, Jeedom will generate sentences with these variations.
We now have slightly more correct sentences with sentences that are not fair, for our example “on” “entry”. so we find “Switch on input “,” Switch on input “,” Switch on input “,” Switch on the entry "etc. So we have all the possible variants with what we added between "\ []" and this for each synonym, which generates quickly a lot of sentences (here 168).
In order to refine and not have improbable things such as “turn on the TV “, we can authorize Jeedom to delete requests syntactically incorrect. So it will delete what is too far away the actual syntax of a sentence. In our case, we go from 168 130 sentence sentences.
It therefore becomes important to build your model sentences well and synonyms as well as selecting the right filters so as not to generate too many unnecessary sentences. Personally, I find it interesting to have some inconsistencies of the style "an entry" because if at home, you have a foreign person who does not speak French correctly, interactions will still work.
Until now, as a response to an interaction, we had a simple sentence that didn't say much except that something happened past. The idea would be that Jeedom tells us what he did a little more precisely. This is where the response field comes in ability to customize return based on order executed.
To do this, we will again use the Jeedom Tag. For our lights, we can use a phrase like : I lit well #equipement# (see screenshot below).
You can also add any value from another command like temperature, number of people, etc.
Binary conversions apply to info type orders whose subtype is binary (returns 0 or 1 only). So you have to activate the right filters, as you can see in the screenshot below (for the categories, we can check all of them, for the example I have kept that light).
As you can see here, I have kept almost the same structure for demand (it's voluntary to focus on specificities). Of course, I adapted the synonyms to have some coherent thing. However, for the answer, it is imperative de put only #valeur# which represents the 0 or 1 that Jeedom is going replace with the following binary conversion.
Field Binary conversion must contain 2 answers : first the response if the value of the command is 0, then a vertical bar “|” separation and finally the response if the command is worth 1. Here the answers are simply no and yes but we could put a sentence a little bit longer.
Warning
Tags do not work in binary conversions.
The "Authorized users" field allows you to authorize only certain people to execute the command you can put multiple profiles separating them with a “|”.
| Example : personne1 | personne2 |
One can imagine that an alarm can be activated or deactivated by a child or a neighbor who would come to water the plants in your absence.
It is possible to create Regexp of exclusion, if a generated sentence corresponds to this Regexp it will be deleted. The point is to be able to remove false positives, to say a sentence generated by Jeedom which activates something which does not does not correspond to what we want or which would interfere with another interaction that would have a similar sentence.
We have 2 places to apply a Regexp :
in the interaction even in the “Regexp exclusion” field”.
In the Administration → Configuration → Interactions menu → "Regexp" field general exclusion for interactions”.
For the field "General exclusion regex for interactions", this rule will be applied to all interactions, which will be created or saved again afterwards. If we want to apply it to all existing interactions, interactions need to be regenerated. Usually it is used to erase sentences incorrectly found in most of the interactions generated.
For the "Regexp exclusion" field in the configuration page of each interaction, we can put a specific Regexp that will act only on said interaction. So it allows you to delete more specifically for an interaction. It can also allow delete an interaction for a specific command for which does not want to offer this opportunity as part of a generation of multiple orders.
The following screenshot shows the interaction without the Regexp. In the left list, I filter the sentences to show you only the sentences to be deleted. In reality there are 76 sentences generated with the configuration of the interaction.
As you can see on the following screenshot, I added a regexp simple which will search for the word "Julie" in the generated sentences and delete them. However, we can see in the list on the left that there always has sentences with the word "julie" in expressions regular, Julie is not equal to julie, this is called a case sensitivity or in good French a capital letter is different of a tiny. As we can see in the following screenshot, it does not only 71 sentences left, the 5 with a "Julie" have been deleted.
A regular expression is composed as follows :
First, a delimiter, here it is a slash "/" placed in beginning and end of expression.
The dot after the slash represents any character, space or number.
The "*" indicates that there can be 0 or more times the character that precedes it, here a point, so in good French any item.
Then Julie, which is the word to look for (word or other diagram expression), followed by a dot again and a forward slash.
If we translate this expression into a sentence, it would give "seek the word Julie which is preceded by anything and followed by anything quoi”.
It's an extremely simple version of regular expressions but already very complicated to understand. It took me a while to grasp it the operation. As a slightly more complex example, a regexp for verify a URL :
Once you can write this, you understand the expressions regular.
To solve the problem of upper and lower case, we can add to our expression an option that will make it case-insensitive, or in other words, which considers a lowercase letter equal to a capital letter; to do this, we simply have to add at the end of our expression a “i”.
With the addition of the option "i" we see that there are only 55 left generated sentences and in the list on the left with the julie filter for look for the sentences that contain this word, we see that there are some Much more.
As this is an extremely complex subject, I will not go further detail here, there are enough tutorials on the net to help you, and don't forget that Google is your friend too because yes, he is my friend, it was he who taught me to understand Regexp and even to code. Therefore if he helped me, he can also help you if you put good volonté.
Useful links :
http://www.commentcamarche.net/contents/585-javascript-l-objet-regexp
https://www.lucaswillems.com/fr/articles/25/tutoriel-pour-maitriser-les-expressions-regulieres
It is also possible to put several info commands in one answer, for example to get a situation summary.
In this example we see a simple sentence that will return a answer with 3 different temperatures, so here we can put a little everything you want in order to have a set of information in one one time.
So the question is “is there anyone in the room”
The answer will be "no there is no one in the room" or "yes there is has someone in the room”
The command that responds to that is "# \ [Chamber of julie ] \ [GSMF-001-2 ] \ [Presence ] #”
This example specifically targets specific equipment which allows to have a personalized response. So we could imagine replacing the example answer with "no there is no one in the room julie|yes there is someone in the room julie”
| So the question is “#commande# [in the | in the] #objet#” |
The answer will be "no there is no one in the room" or "yes there is someone in the room”
There is no command which answers that in the Action part seen that this is a Multiple commands interaction
Without the Regexp, we get here 11 sentences, but my interaction is aimed generate sentences only to ask if there is someone in a room, so I don't need a lamp condition or anything like the taken, which can be resolved with regexp filtering. To give back even more flexible, synonyms can be added, but in this case it don't forget to modify the regexp.
We could write the sentence hard like for example "what is the living room temperature ", but one should be done for each sensor of temperature, brightness and humidity. With the generation system of Jeedom sentence, so we can generate with a single interaction sentences for all the sensors of these 3 types of measurement.
Here a generic example which is used to know the temperature, the humidity, the brightness of the different rooms (object in the Jeedom sense).
So we can see that a generic generic sentence "What is the living room temperature “or” How bright is the bedroom” can be converted to : “what is the |l \ ‘] #commande# objet” (the use of \ [word1 | mot2 ] lets say this possibility or this one to generate all possible variations of the sentence with word1 or word2). When generating Jeedom will generate all possible combinations of sentences with all commands existing (depending on filters) by replacing #commande# par the name of the command and #objet# by the name of the object.
The answer will be “21 ° C” or “200 lux”. Just put : #valeur# #unite# (the unit is to be completed in the configuration of each order for which we want to have one)
This example therefore generates a sentence for all the commands of type digital info that have a unit, so we can uncheck units in the right filter limited to the type that interests us.
We can therefore add synonyms to the command name to have some more natural thing, add a regexp to filter the commands that have nothing to do with our interaction.
Adding a synonym, lets tell Jeedom that a command called “X” can also be called “Y” and therefore in our sentence if we have “turn on y ", Jeedom knows it's turning on x. This method is very convenient to rename command names which, when displayed at the screen, are written in a way that is not natural vocally or in a sentence written like “ON”. A button written like this is totally logical but not in the context of a sentence.
We can also add a Regexp filter to remove some commands. Using the simple example, we see sentences "battery" or “latency “, which have nothing to do with our interaction temperature / humidity / brightness.
So we can see a regexp :
| **(batterie | latence | pression | vitesse | consommation)** |
This allows you to delete all orders that have one of these words in their sentence
NOTE
The regexp here is a simplified version for easy use. So we can either use traditional expressions or use the simplified expressions as in this example.
It is possible to control a percentage lamp (dimmer) or a thermostat with interactions. Here is an example to control its dimmer on a lamp with interactions :
NOTE
You can use any tag except those already used by Jeedom, there can be several to drive for example multiple orders. Also note that all tags are passed to scenarios launched by the interaction (however, the scenario either in “Run in foreground”).
We may want to control all cursor type commands with a single interaction. With the example below, we will be able to order several drives with a single interaction and therefore generate a set of sentences to control them.
In this interaction, we have no command in the action part, we let Jeedom generate from tags the list of sentences. We can see the tag #slider#. It is imperative to use this tag for instructions in a multiple command interaction it may not be the last word of the sentence. We can also see in the example that we can use in the response a tag which is not part of the request. The majority of the tags available in the scenarios are also available in interactions and therefore can be used in an answer.
Result of the interaction :
We can see that the tag #equipement# which is not used in the request is well completed in the response.
It is possible to control a color command by the interactions in asking Jeedom for example to light a blue LED strip. This is the interaction to do :
Until then nothing very complicated, it must however have configured colors in Jeedom to make it work; go to the menu → Configuration (top right) then in the section “Configuring interactions” :
As we can see on the screenshot, there is no color configured, so add colors with the "+" on the right. The color name, this is the name you are going to pass to the interaction, then in the right part (column "HTML code"), by clicking on the black color you can choose a new color.
We can add as many as we want, we can put as a name any one, so you could imagine assigning a color to the name of each family member.
Once configured, you say "Light the tree green", Jeedom will find a color in the request and apply it to the order.
It is possible to couple an interaction to a scenario in order to perform slightly more complex actions than performing a simple action or request for information.
This example therefore makes it possible to launch the scenario which is linked in the action part, we can of course have several.
Interactions do a lot of things in particular. You can program an action dynamically. Example : “Put it on heating at 10 p.m. for 2:50 p.m”. Nothing could be simpler, just to use tags #time# (if a specific time is defined) or #duration# (for in X time, example in 1 hour) :
NOTE
You will notice in the response the tag #value# this one contains in the case of a scheduled interaction, the programming time effective
